I am hosting Hestia on Oracle Always free vps. I am unable to access the phpmyadmin panel. It is returning an error. Please help. How to access my phpmyadmin panel ?
This Chinese article can help you Mariadb数据库PHPMYADMIN mysqli_real_connect(): (HY000/1698): Access denied for user错误的正确解决办法 - IDC评估网
I did the same but I am getting the same error ?
Please help as soon as possible
If you have cloudflare enabled disable it
Should I disable cloudfare for the server.chiragnahata.ml only ?
Like my server is working but not the phpmyadmin
i’m with the same problem.
the error:
Existing configuration file (/etc/phpmyadmin/config.inc.php) is not readable.
2 years later, do you have an answer to this problem?
chmod 644 /etc/phpmyadmin/config.inc.php
chgrp www-data is probably better.
Same on /usr/share/phpmyadmin/tmp
