Hi guys, so the short explanation is that anybody who has the Hestia Control Panel will lose the PhpMyAdmin features ?
This is cringe worthy … even if there was a problem related to security, this could have been better treated, not by just killing all PhpMyAdmin acces …
Basicaly this will make me to change the panel to another one, because i need PhpMyAdmin …
Damn guys, this is hurting me so much … i’ve got use to it so much …
So, actually it’s working, but you need to work with it from a domain name. Not a problem then, just had a problem with an Owncloud installation, and i taught that this was a bummer and something was bad, i will try to make it work somehow…
Wierd that this was closely connected, and i somehow blamed Hestia CP.
For Apache in 1.4.x and before PHPmyadmin was accessible via hostname, any domain or ip. Even with a custom template you where not able to disable this behavior
For Nginx in all versions: PHPmyadmin is only accessible via Hostname and any Domain and with custom template you can disable it …
We just changed the “hostname” / “domain” config system for Nginx and also applied it to Apache2 so in both cases the behavior is similar…
