Please tell me why, when automatically logging into a remote database, the PMA database is pulled from the local server instead of the remote server where it was created.
Because of this, the databases aren’t showing up and the login isn’t working correctly.
If I log into the remote database using my username and password, everything is fine.
But the auto-login isn’t working.
mysqli::real_connect(): (HY000/1045): Access denied for user ‘pma’@‘localhost’ (using password: YES)
Connection for controluser as defined in your configuration failed.
It is unclear why, when logging into a remote database, it pulls up localhost instead of the address of the remote database and the password that is written in /etc/phpmyadmin/conf.d/01-remote.php
A “to many redirect” message pops up for a couple of seconds and then redirects you to the phpMyAdmin login page. Autologin for the remote server doesn’t work.
A phpmyadmin database has been created on the remote server. Login with username and password works perfectly. A separate file named 01-remote.php has been created in /etc/phpmyadmin/conf.d for the remote server.
211261 [Warning] Access denied for user ‘hestia_sso_RWIqHqyCgDduzQA3’@‘192.168.25.10’ (using password: YES)
I see this in the database server logs when attempting to auto-login to phpMyAdmin.
When creating a user, the control panel uses localhost instead of %.
In short, the panel creates a temporary user with the host localhost.
Since we’re using a remote server, it would be logical to allow access for all hosts “%”
Where can I change the logic in the panel scripts?
I can help test auto-login on remote servers if you’re interested in any modifications to the panel.
Edit file /usr/local/hestia/func/db.sh and modify add_mysql_database_temp_user and delete_mysql_database_temp_user functions replacing @localhost with @'%' if you want to allow connections from everywhere.
Dear panel developers! Please include these changes in the global panel update. This is critical when using a remote MySQL server.
Also, if possible, provide the ability to hide the localhost database server when using remote servers.
I would like to add my two cents. If you’re using MySQL HeatWave from Oracle OCI as a remote DB, the generated password does not meet the password criteria, and the DB temp user still fails.
You’ll also need to patch the `/usr/local/hestia/bin/v-add-database-temp-user` file and replace the `dbpass` variable with:
