hello, when I was trying to install medusajs I think port 9000 was used in the php system and the php crashed due to a conflict. I cannot access both panels phppgadmin and phpmyadmin
root@admin:~# sudo systemctl status postgresql
● postgresql.service - PostgreSQL RDBMS
Loaded: loaded (/lib/systemd/system/postgresql.service; enabled; vendor preset: enabled)
Active: active (exited) since Sun 2024-02-18 20:58:03 +03; 21min ago
Process: 1765 ExecStart=/bin/true (code=exited, status=0/SUCCESS)
Main PID: 1765 (code=exited, status=0/SUCCESS)
CPU: 1ms
Feb 18 20:58:03 admin.upcreate.art systemd[1]: Starting PostgreSQL RDBMS...
Feb 18 20:58:03 admin.upcreate.art systemd[1]: Finished PostgreSQL RDBMS.
root@admin:~# sudo systemctl status mysql
● mariadb.service - MariaDB 10.11.7 database server
Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mariadb.service.d
└─migrated-from-my.cnf-settings.conf
Active: active (running) since Sun 2024-02-18 20:58:01 +03; 21min ago
Docs: man:mariadbd(8)
https://mariadb.com/kb/en/library/systemd/
Process: 798 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
Process: 826 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 865 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= || VAR=`cd /usr/bin/..; /usr/bin/galera_recovery`; [ $? -eq 0 ] && systemctl set-enviro>
Process: 1098 ExecStartPost=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
Process: 1110 ExecStartPost=/etc/mysql/debian-start (code=exited, status=0/SUCCESS)
Main PID: 1027 (mariadbd)
Status: "Taking your SQL requests now..."
Tasks: 9 (limit: 14655)
Memory: 143.9M
CPU: 1.800s
CGroup: /system.slice/mariadb.service
└─1027 /usr/sbin/mariadbd
Feb 18 20:57:59 admin.upcreate.art systemd[1]: Starting MariaDB 10.11.7 database server...
Feb 18 20:58:01 admin.upcreate.art systemd[1]: Started MariaDB 10.11.7 database server.
Feb 18 20:58:01 admin.upcreate.art /etc/mysql/debian-start[1115]: Upgrading MySQL tables if necessary.
Feb 18 20:58:01 admin.upcreate.art /etc/mysql/debian-start[1220]: Triggering myisam-recover for all MyISAM tables and aria-recover for all Aria tables
[1]+ Stopped
