Can someone guide me where should increase pm.max_children ?
Thank you so much
Thank you so much
Create a new template and edit the number there
Is not recommended to modify in /usr/local/hestia/data/templates/web/php-fpm/ ?
No but you can create new ones without any issues just rename them like: xxxx-PHP-8_x
where 8_x is the php version
I need to modify for PHP-7_4.tpl . So just copy into NEW-PHP-7_4.tpl and modify there?! Then rebuild user?
Thank you so much, eris !
Yes and update php-fpm template in UI ![]()
