Working on integrating hestia into my customer management system and came to the point where I want to make PMA SSO from my system.
There is v-add-database-temp-user and v-delete-database-temp-user. With addition I receive these details:
"login": {
"user": "hestia_sso_ncy4xE75kwnwN87h",
"password": "T0dF2aMOJ3WbLeTR"
Now, how to actually SSO to https://server.domain.tld/phpmyadmin ? I can’t use hestia_sso.php as it designed for internal hestia use. Should I implement my own SSO php script?
eris
September 2, 2023, 2:17pm
2
You should be able call
https://server.domain.tld/phpmyadmin/hestia-sso.php?database= <?= $key ?>&user=<?= $user_plain?>&exp=<?= $time?>&hestia_token=<?=password_hash($key.$user_plain.$_SESSION['user_combined_ip'].$time.$_SESSION['PHPMYADMIN_KEY'], PASSWORD_DEFAULT) ?>
Database: Database name
User: Hestia Username
Time: Current time
hestia_token: <?=password_hash($key.$user_plain.$_SESSION['user_combined_ip'].$time.$_SESSION['PHPMYADMIN_KEY'], PASSWORD_DEFAULT) ?>
$key = database
$user_plain = Username
$_SESSION[‘user_combined_ip’] = IP address of the user
$time = current time
$_SESSION[‘PHPMYADMIN_KEY’]
PHPMYAdmin key
eris:
PHPMYADMIN_KEY
How this can by obtained via API? I have multiple servers with different API keys on each one.
eris
September 2, 2023, 3:31pm
4
V-list-sys-config if I am right
v-list-access-keys admin json
And there is a bug, when v-list-access-keys json it prints shell format… Only with user provided json is formed. Anyway, thank you!
