Port 25 without encryption
hello
I am trying to configure an SMTP email client on port 25 but it does not work if I put some encryption on it.
In previous versions it was possible.
Have you made any changes?
I can’t use 25 without encryption?
regards
Hello @GabrielPL,
Yes, there was a change to allow auth only on localhost and TLS connections:
You shouldn’t, your passwords will be sent in clear text over the net. If you know your client ip and it isn’t a dynamic ip you could add it to auth_advertise_hosts directive in /etc/exim4/exim4 conf.template
auth_advertise_hosts = localhost : ${if eq{$tls_in_cipher}{}{}{*}}
If you want to add ip 203.0.113.1:
auth_advertise_hosts = localhost : 203.0.113.1 : ${if eq{$tls_in_cipher}{}{}{*}}
You could also remove directive auth_advertise_hosts completely and you will be able to use auth on ports 25 and 587 without using a tls connection (I wouldn’t do it).
Cheers,
sahsanu
Thanks!!!
