Port assignment for 1 website
Hello.
I need to change one website , IP address . Port from 80 to 60.
Not my Server IP.
Is this possible ?
Just nginx.
Thank-You
Sid
Don’t worry, I fixed it. Forgot about the conf file in domains :~/
Sid
Yes, you need to create a new web template for nginx and replace %web_port% with 60
listen      %ip%:60;
Assign that new template to your site and rebuild it.
Remember to add a firewall rule to allow port 60.
If you change it there, the port change will be lost when the site is rebuilt.
Thank-You
I’ll do that too.
Sid
