PostgreSQL and 1c
Hello everyone, tell me how to display PostgreSQL from 1s, version 12.0 in the hestia panel among running processes ?, I see PostgreSQL support is declared
Check:
v-add-remote-database-host
And if for dummies, then it comes out v-add-remote-database-host TYPE HOST DBUSER DBPASS [MAX_DB] [CHARSETS] [TPL] ?
just on request v-list-database-hosts gives nothing but mysql
Yes and then you need the correct data…
I am allready providing the command you need to use. What else do we need to explain?
v-add-database-host pgsql 127.0.0.1 postgres ‘pass’
Error: pgsql type is invalid
Make sure to install php postgress and psql dependcies and alter
/usr/local/hestia/conf/hestia.conf:
DB_SYSTEM to DB_SYSTEM=‘pgsql,mysql’
Crap. And if I do not plan to create databases there?. just monitor the status
PostgreSQL via settings
That will not work
We are not able to monitor remote servers …
So the one that was written above is the only way out? That to add at the level with mysql and then it will be possible to monitor?
