Problem sending email
When I send email in the exim4 log it appears
==> mainlog <==
2024-07-19 12:37:29 1sUpfl-002nvO-1G <= [email protected] H=localhost (webmail.netzero.tec.br) [127.0.0.1] P=esmtpa A=dovecot_login:tiago@ netzero.tec.br S=557 [email protected]
2024-07-19 12:37:29 1sUpfl-002nvO-1G == [email protected] R=dnslookup T=remote_smtp defer (-54): retry time not reached for any host for 'tecel.com.br ’
2024-07-19 12:38:50 1sUkv0-002a8s-0u H=gmail-smtp-in.l.google.com [142.250.0.26] Connection timed out
2024-07-19 12:39:32 no host name found for IP address 178.215.236.209
2024-07-19 12:41:01 1sUkv0-002a8s-0u H=alt1.gmail-smtp-in.l.google.com [64.233.184.26] Connection timed out
Can anyone help me with what I need to do, I’ve seen some discussion forums but it seems like the settings here are correct.
port 25 blocked from your provider.
Is there any way to make it work in this case?
contact your provider or use a relay
Yoiu also need to check if the exim4 has following bindings:
mail.netzero.tec.br 200.195.157.154
