Hello, I have rclone configured with Google Drive and it has worked perfectly for quite some time, but now I have problems uploading backup copies that are very large.
I found out about this problem and apparently it is Google adding a type of restriction which is solved by adding --drive-upload-cutoff 1000T to the rclone copy... command.
Reference:
The problem is that I can do this manually but HestiaCP is the one that controls the automatic uploads, how could I modify it so that --drive-upload-cutoff 1000T is included in the command and not have that problem?
