Hello, do you have any reliable websites or tools for generating DKIM, SPF, and DMARC records? Some servers treat my Hestie-generated messages as spam, and I get responses like the one in the image.
In Cloudflare, you added the DKIM info to the wrong place. You added it to your base domain webdesign-studio.com.pl but you must add it to mail._domainkey.webdesign-studio.com.pl subdomain record.
DMARC and SPF is correctly added.
In Name field remove the base domain and add mail._domainkey
Yes, seems so.
Thanks for your help. I think my email will be working normally now. Now I have to wait 24 hours?
You’re welcome.
No, it should work now.
You should create a PTR record for your current public IP that resolves to the same hostname your mail server uses to identify itself, in this case webdesign-studio.com.pl.
Note: The PTR record must be created on your hosting side, not Cloudflare.
You can also test your mail server using this site:
Yes, but usually you should be able to change it through the control panel provided by your hosting company.
Unfortunately, I can’t because they also added revdns to me, I don’t have that option.
Sorry, I don’t understand what you mean.
I wanted to write that my hosting provider did not provide these options in the panel, such as adding prt and revdns records, I just have to write a ticket and they will add it.
Hello, me and my friends who use Hestia mail with me still get this reply after sending a message:
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
host mail.nsm.org.pl \[195.78.66.221\]
SMTP error from remote mail server after end of data:
550-Your message to <[[email protected]](mailto:[email protected] "mailto:[email protected]")> was classified as SPAM. Please add
550-more content, cut down on HTML links, use fewer naughty words etc. Also,
550-ask your IT dept to make sure your mailserver has REVERSEDNS, SPF, DKIM,
550 and is not on any black lists. Your score:
170
can i fix it somehow revdns and prt records added.
The second command should return webdesign-studio.com.pl but it returns nothing.
❯ dig webdesign-studio.com.pl +short
83.168.108.58
❯ dig -x 83.168.108.58 +short
Example of an IP with a PTR configured:
❯ dig mail.hestiacp.com +short
116.203.78.202
❯ dig -x 116.203.78.202 +short
web02.hestiacp.com.
Your hosting provider didn’t add the PTR record for your IP. You should contact them about this.
