Problem with instalation HestiaCP on debian 10
            _   _           _   _        ____ ____
           | | | | ___  ___| |_(_) __ _ / ___|  _ \
           | |_| |/ _ \/ __| __| |/ _` | |   | |_) |
           |  _  |  __/\__ \ |_| | (_| | |___|  __/
           |_| |_|\___||___/\__|_|\__,_|\____|_|
                      Hestia Control Panel
                              1.5.1
                        www.hestiacp.com
Thank you for downloading Hestia Control Panel! In a few moments,
we will begin installing the following components on your server:
  • NGINX Web / Proxy Server
  • Apache Web Server (as backend)
  • PHP-FPM Application Server
  • Bind DNS Server
  • Firewall (Iptables) + Fail2Ban Access Monitor
Would you like to continue with the installation? [Y/N]: Y
Installation backup directory: /root/hst_install_backups/111220211424
Installation log file: /root/hst_install_backups/hst_install-111220211424.log
[ * ] NGINX
[ * ] PHP
[ * ] Apache2
[ * ] Hestia Control Panel
Updating currently installed packages, please wait… W: GPG error: https://apt.hestiacp.com buster InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY A189E93654F0B0E5
E: The repository ‘https://apt.hestiacp.com buster InRelease’ is not signed.
Error: apt-get install failed
Solution: No_pubkey a189e93654f0b0e5 - #2 by ScIT
