Problem with Laravel project
Issue Description:
Attempting to install a Laravel project
Atlas Laravel Business Directory Listing
https://codecanyon.net/item/atlas-laravel-business-directory-listing/56469797
on Debian 12 with HestiaCP 1.9.4 results in a Gateway Timeout. All logs (Apache, PHP-FPM, Laravel) are empty.
Fresh install Debian12 and updates
The problem doesn’t occur on other hosting “Timeweb”
Project installs quickly and easily.
Environment:
  • OS: Debian 12
  • HestiaCP: 1.9.4
  • PHP: 8.2 (CLI and FPM)
Symptoms:
  1. Running:
cd /home/USER/web/DOMAIN/public_html
php8.2 artisan --version
→ Cursor hangs, command does not complete.
  1. Apache error:
    AH01075: Error dispatching request to : (polling)
Diagnostics performed:
  • open_basedir is disabled (no value).
  • Standard PHP script <?php echo 'OK'; works fine.
Problem:
No errors appear in logs. Web requests return Gateway Timeout.
Request:
  • Are there known issues with HestiaCP 1.9.4 running Laravel on Debian 12 with PHP 8.2 that?
  • Any recommended steps to diagnose or resolve Laravel execution issues under HestiaCP?
Additional info:
strace results are available for deeper analysis if needed.
Thank you for your assistance!
Hestia Control Panel Version
1.9.4
Operating system
Debian 12
I’ve done a Laravel domain today by using completely default settings. After finding that Laravel is in the Quick install options.
I am on Ubuntu 24.04 LTS though.
  1. Changed web domain’s setting from default to Laravel pre-set option.
  2. Installed composer with -g option and all worked fine did not have to do anything
Let me know if you want to compare configs or someting..
