Problem with remote backups (not enough disk space)
Hello, I’m getting this error:
Not enough disk space available (42430 mb) to perform the backup of luka. ( 25415 mb * 2 = 50830 mb). Backup & Restore | Hestia Control Panel
the backups are remote only, and there is 5TB space on the remote storage.
Also, this is internal storage:
Filesystem      Size  Used Avail Use% Mounted on
udev            3.8G     0  3.8G   0% /dev
tmpfs           775M  720K  775M   1% /run
/dev/sda1        75G   31G   42G  43% /
tmpfs           3.8G  1.2M  3.8G   1% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
/dev/sda15      241M  138K  241M   1% /boot/efi
tmpfs           775M     0  775M   0% /run/user/0
local /backups directory is empty.
Backups are created local first and then copied over to remote location
