Problem with request URI in redirections. double slash
I think there is a problem with my redirections in hestiacp.
I wanted to use hestiaCP integrated domain redirection from https://fr.domain.com/url/ to https://domain.com/fr/url/
So, I have added as redirection:
https://aliane.net/fr/
Then, I discovered that hestia added an unecessary slash
when I typed: https://fr.domain.com/the-url/ it redirected to https://domain.com/fr//the-url/
So i looked into the nginx.conf_redirect file
and i found return 301 https://aliane.net/fr/$request_uri;
So, i think it is a mistake because the $request_uri already include a slash. so I think the right line should be return 301 https://aliane.net/fr$request_uri;
Maybe the problem came from me but when I removed the the slash in the custom address (https://domain.com/fr) the $request_uri disappeared in the nginx file.
`return 301 https://aliane.net/fr
In other words, if I entered https://fr.aliane.net/a-url/ and then i only got https://aliane.net/fr
Maybe i did something wrong? How can I get the URL at the end of the redirected URL without double slash?
I wish to find the set up to get: the following in nginx redirection file:
What version are you on?
Nevermind can verify the issue with the last version
See:
