Problem with update
I’ve a problem to update from v1.6.8 to latest.
I found somewhere here there are some bug need to update manually using this command “v-update-sys-hestia-all” and fail , I notice the problem come aside from hestia and run same command again and seem “work fine”.
Then i update system all fine here. I go to the panel in “Server Settings” i notice lost many service listed there and not sure why.
I’m using Debian 10 hestia v1.8.5. Server from the moment work fine and i have all services such php, db, web and the other service is used by hestia.
I reboot server for just case and still not list the services.
Any idea what happen and how to fix.
Check /var/log/hestia/ngninx-error.log
2023/08/15 16:07:55 [error] 43932#0: *81 FastCGI sent in stderr: "PHP message: PHP Fatal error: Uncaught TypeError: ngettext(): Argument #3 ($count) must be of type int, string given in /usr/local/hestia/web/inc/main.php:329
Stack trace:
#0 /usr/local/hestia/web/inc/main.php(329): ngettext()
#1 /usr/local/hestia/web/templates/pages/list_services.php(197): humanize_time()
#2 /usr/local/hestia/web/inc/main.php(202): include('...')
#3 /usr/local/hestia/web/list/server/index.php(137): render_page()
#4 {main}
thrown in /usr/local/hestia/web/inc/main.php on line 329" while reading upstream, client: x.x.x.x, server: _, request: "GET /list/server/ HTTP/2.0", upstream: "fastcgi://unix:/run/hestia-php.sock:", host: "x.x.x.x:8083", referrer: "https://x.x.x.x:8083/list/rrd/"
