Problems with hestia panel prestashop pre-installation
good morning
I need to install version 8.1 to be able to install the version that hestiacp pre-installs but it gives me an error:
v-add-web-php 8.1
Installing PHP-8.1, please wait…
ERROR: Installation failed, please run the following command manually for debugging:
apt-get install php8.1-common php8.1-mbstring php8.1-bcmath php8.1-cli php8.1-curl
php8.1-fpm php8.1-gd php8.1-intl php8.1-mysql
php8.1-soap php8.1-xml php8.1-zip php8.1-bz2
php8.1-pspell php8.1-imagick php8.1-imap php8.1-ldap
How can I install php 8.1 or what preinstallation from prestashop that can be installed from hestia panel, allow to use php 8.2?
What happens if you run this command via SSH
cp: cannot create regular file ‘/etc/php/8.1/fpm/pool.d/’: No such file or directory
sed: cannot read /etc/php/8.1/fpm/pool.d/dummy.conf: No such file or directory
cp: cannot create regular file ‘/etc/php/8.1/fpm/’: No such file or directory
sed: cannot read /etc/php/8.1/fpm/php-fpm.conf: No such file or directory
sed: cannot read /etc/php/8.1/fpm/php.ini: No such file or directory
sed: cannot read /etc/php/8.1/cli/php.ini: No such file or directory
I have already been able to solve it
The problem was that the sourcelist of /etc/apt/sources.list.d/ that includes hestiacp had not been updated when I updated debian 11 to 12, I changed the previous name to bookworm and now it has been able to install php8.1
Thank you
