Hi!
I have upgraded the hestia panel to 1.9.1
After doing it, panel returns a 502 error and is not able to get hestia config at /usr/local/hestia/web/inc/main.php:549
This line executes the script
v-list-sys-config json
Returned array is always empty and this causes an exception later when it tries to recover a specific variable.
The script is correctly executed by terminal.
It seems something related with permissions.
If I check the conf file at
/etc/php/8.0/fpm/pool.d/panel_domain.conf
these are the permissions assigned to the panel:
listen.owner = admin
listen.group = www-data
listen.mode = 0660
user = admin
group = admin
Any clue on what I have to check to ensure that panel has the right permissions to execute the hestia sys scripts?
