Problems with the Let's Encrypt SSL certificate
Good afternoon.
I am having problems with the Let’s Encrypt SSL certificate on one of my domains.
It is not a new domain or installation, so I can’t figure out why it is not working properly.
Neither from the HestiaCP panel nor via SSH with
v-add-letsencrypt-domain user domain
It hangs and even takes down the whole VPS.
Any idea how to fix it?
Well, thanks to @eris and @sahsanu I found the problem and the solution here:
Have you added a http redirection in /home/user/cont/web/yourdomain.com/nginx.conf_xxx
that could prevent let’s encrypt from creating a ssl certificate?
