According to the documentation, Prohibit-password only allows login by key.
However, I notice that it is possible for me to connect in SFTP with the root login…
Is this normal?
Thank you.
I am using HestiaCP 1.24 on Debian 10.
Is this normal?
Thank you.
Yes, this is normal and by design. If you want to limit it to key auth only, please adjust you sshd_conf: https://serverpilot.io/docs/how-to-disable-ssh-password-authentication/
Thank you very much for your answer.
Is it something you would recommand?
I use it my self. There is no reason to use an password any more… Much easier… Make sure you backup the keys to cloud an you are fine
I see. Thank you again!
