Protect phpmyadmin with http basic auth
I’d like to protect phpmyadmin with http basic auth.
So what was done:
  1. I added to file /etc/phpmyadmin/apache.conf
    after line <Directory /usr/share/phpmyadmin>
AuthType Basic
AuthName "Restricted Access"
AuthUserFile /usr/share/phpmyadmin/passwd
Require valid-user
  1. After that new password was generated
    htpasswd -c /usr/share/phpmyadmin/passwd user
  2. Configuration test
    apachectl configtest
  3. Apache was restarted
    systemctl restart apache2 && systemctl status apache2
As a result I don’t see authorization window. Can anybody please help me, where is my error?
/etc/phpmyadmin/apache.conf is not loaded
Use /etc/apache2/conf.d/conf.d/phpmyadmin.conf instead
Great! Thanks, now it works as it should!
Please be aware that we sometimes renew the config file
For example 1.4.15 release …
So update process will overwrite config. Right?
Usually we don’t overwrite the phpmyadmin config how ever in this case due to some security “remarks” it makes for us easier to overwrite 1 config file then sed in all the changes.
