Protecting Hestia with nginx-ultimate-bad-bot-blocker
Hello everyone, I’m trying to configure nginx-ultimate-bad-bot-blocker, and I’m faced with a lack of understanding where to add blocks [from this example.](GitHub - mitchellkrogza/nginx-ultimate-bad-bot-blocker: Nginx Block Bad Bots, Spam Referrer Blocker, Vulnerability Scanners, User-Agents, Malware, Adware, Ransomware, Malicious Sites, with anti-DDOS, Wordpress Theme Detector Blocking and Fail2Ban Jail for Repeat Offenders blob/master/_sample_config_files/SAMPLE-Nginx-SSL-Site-Config-Example.md)
What did I do
  1. I installed nginx-ultimate-bad-bot-blocker manually according to the instructions . When installing, please note that the botblocker-nginx-settings.conf file has entries that conflict with the Nginx Hestia configuration (they should be deleted)
  2. After the basic installation, the example shows what is added
    include /etc/nginx/bots.d/blockbots.conf;
    include /etc/nginx/bots.d/ddos.conf;
server {
	# SSL configuration
	listen 443 ssl http2;
	root /var/www/yourdomain.com;
	server_name yourdomain.com www.yourdomain.com;
	charset UTF-8;
	# Logging for the SSL version of our site
	access_log /var/log/nginx/yourdomain.com-access.log;
	error_log /var/log/nginx/yourdomain.com-error.log;
	# SSL Configuration
	# First include our certificates and chain of trust - Using Let's Encrypt Free SSL
	ssl_certificate /etc/letsencrypt/live/yourdomain.com/fullchain.pem;
	ssl_certificate_key /etc/letsencrypt/live/yourdomain.com/privkey.pem;
	ssl_trusted_certificate /etc/letsencrypt/live/yourdomain.com/chain.pem;
	# Diffie-Hellman parameter for DHE ciphersuites, recommended 2048 bits
	ssl_dhparam /etc/nginx/ssl/dhparam.pem;
	ssl_session_timeout 1d;
	ssl_session_cache shared:SSL:128m;
	ssl_session_tickets off;
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
	# ciphers recommended by https://mozilla.github.io/server-side-tls/ssl-config-generator/
	ssl_ciphers 'ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS';
	ssl_prefer_server_ciphers on;
	add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
	ssl_stapling on;
	ssl_stapling_verify on;
	# Include our X- Headers for Browser Cross-Sniffing
        add_header X-Frame-Options SAMEORIGIN;
        add_header X-Content-Type-Options nosniff;
        add_header X-XSS-Protection "1; mode=block";
	# ADD THE NGINX BAD BOT BLOCKER HERE (Please read full setup instructions)
	# Include Any Custom Configurations and Location Directives Here
# END OF SSL HOST CONFIG - CLOSING BRACE BELOW THIS LINE
and
server {
    # NOW WE REDIRECT ALL PORT 80 TRAFFIC TO PORT 443
	listen 80;
	# Block Bad Bots even before they even get redirected
      return 301 https://yourdomain.com$request_uri;
    # HAVE SEPARATE LOGGING FOR PORT 80 (otherwise use same log location as SSL site)
	access_log /var/log/nginx/yourdomain.com-80-access.log;
	error_log /var/log/nginx/yourdomain.com-80-error.log;
# END OF HTTP PORT 80 HOST CONFIG - CLOSING BRACE BELOW THIS LINE
I did this on my third-party resource PeerTube, and everything is fine
server {
  listen 80;
  listen [::]:80;
  server_name angeltales.angellive.ru;
  #nginx-ultimate-bad-bot-blocker
      return 301 https://angeltales.angellive.ru$request_uri;
  location /.well-known/acme-challenge/ {
    default_type "text/plain";
    root /var/www/certbot;
  location / { return 301 https://$host$request_uri; }
upstream backend {
  server 127.0.0.1:9000;
server {
  listen 443 ssl;
  listen [::]:443 ssl;
  listen 443 quic reuseport;
  listen [::]:443 quic reuseport;
  access_log /var/log/nginx/peertube.access.log; # reduce I/0 with buffer=10m flush=5m
  error_log  /var/log/nginx/peertube.error.log;
  # Certificates
  # you need a certificate to run in production. see https://letsencrypt.org/
  ssl_certificate     /etc/letsencrypt/live/angeltales.angellive.ru/fullchain.pem;
  ssl_certificate_key /etc/letsencrypt/live/angeltales.angellive.ru/privkey.pem;
  location ^~ '/.well-known/acme-challenge' {
  # Security hardening (as of Nov 15, 2020)
  # based on Mozilla Guideline v5.6
  ssl_protocols             TLSv1.3;
  ssl_ciphers               ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256; # add ECDHE-RSA-AES256-SHA if you want compatibility with Android 4
  ssl_session_timeout       1d; # defaults to 5m
  ssl_session_cache         shared:SSL:10m; # estimated to 40k sessions
  ssl_stapling              on;
  # HSTS (https://hstspreload.org), requires to be copied in 'location' sections that have add_header directives
  #add_header Strict-Transport-Security "max-age=63072000; includeSubDomains";
  # Advertise HTTP/3 support
  add_header Alt-Svc 'h3=":443"; ma=86400';
  add_header QUIC-Status $http3;
# rest of the configuration
Since we have templates in Hestia, adding a redirect creates errors, while I do not touch the main Nginx configuration file. but only templates from /usr/local/hestia/data/templates/web/nginx/php-fpm
server {
	listen      %ip%:%web_port%;
      return 301 https://%domain_idn%$request_uri;
	root        %docroot%;
	location = /favicon.ico {
		log_not_found off;
		access_log off;
	location = /robots.txt {
		log_not_found off;
		access_log off;
		deny all;
		return 404;
	location / {
		location ~* ^.+\.(ogg|ogv|svg|svgz|swf|eot|otf|woff|woff2|mov|mp3|mp4|webm|flv|ttf|rss|atom|jpg|jpeg|gif|png|webp|ico|bmp|mid|midi|wav|rtf|css|js|pdf|jar)$ {
			expires 365d;
		location ~* /(?:uploads|files)/.*.php$ {
			deny all;
			return 404;
		location = /xmlrpc.php {
				deny all;
				access_log off;
				log_not_found off;
				return 403;
		location ~ [^/]\.php(/|$) {
			try_files $uri =404;
			fastcgi_index index.php;
			fastcgi_param HTTP_HOST $host;
			fastcgi_pass %backend_lsnr%;
			if ($request_uri ~* "/wp-admin/|/wp-json/|wp-.*.php|xmlrpc.php|index.php|/store.*|/cart.*|/my-account.*|/checkout.*") {
				set $no_cache 1;
			if ($http_cookie ~* "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_no_cache|wordpress_logged_in|woocommerce_items_in_cart|woocommerce_cart_hash|PHPSESSID") {
				set $no_cache 1;
	location /error/ {
	location /vstats/ {
After building v-rebuild-web-domains user and checking nginx -t I get
nginx: [emerg] "limit_conn" directive is duplicate in /etc/nginx/bots.d/blockbots.conf:55
nginx: configuration file /etc/nginx/nginx.conf test failed
root@hestia:~# grep -r "limit_conn" /etc/nginx/
/etc/nginx/bots.d/ddos.conf:limit_conn addr 200;
/etc/nginx/bots.d/blockbots.conf:#limit_conn bot1_connlimit 100;
/etc/nginx/bots.d/blockbots.conf:limit_conn bot2_connlimit 10;
/etc/nginx/bots.d/blockbots.conf:#limit_conn bot4_connlimit 10;
/etc/nginx/conf.d/botblocker-nginx-settings.conf:limit_conn_zone $binary_remote_addr zone=addr:50m;
/etc/nginx/conf.d/globalblacklist.conf: #limit_conn bot1_connlimit 100;
/etc/nginx/conf.d/globalblacklist.conf: limit_conn_zone $bot_iplimit zone=bot2_connlimit:16m;
/etc/nginx/conf.d/globalblacklist.conf: limit_conn_zone $bot_iplimit2 zone=bot4_connlimit:16m;
However, on a server without Hestia everything is fine. If anyone has experience using this product on Hestia, please tell me what can be fixed and where. Thank you
