Hi
Is there a way to create rDNS record from the Panel?
BR,
Neven
Hi
BR,
Neven
Hi @neven
Basicly yes, but I think you want to add it on the wrong point: If you have a vps or dedicated server, you have to ask your hosting provider to add the records, mostly you can do it over the backend.
If you have your own IP subnet, you would need a dns cluster and add the related PTR records to them.
