Question about Lets Encrypt
Hestia Control Panel: v1.5.0
Debian 10.11 (x86_64)
According to the log below:
“type”: “urn:ietf:params:acme:error:rateLimited”,
“detail”: “Error creating new order :: too many certificates (5) already issue d for this exact set of domains in the last 168 hours: melatoninavix.com,www.mel atoninavix.com: see Rate Limits - Let's Encrypt”,
“status”: 429
do I have to wait 168 hours for a new attempt?
Basicly, yes. Also try to find out, why its failing - you got some 400 error codes before you land in a 429.
There were some attempts due to an error, which I couldn’t identify:
I formatted the vps and reinstalled hestiacp
I had this problem in the past. In the end I didnt have to wait that long.
What was done?
If I keep trying to generate the certificate, the time can increase.
2021-12-01 10:13:12 v-add-letsencrypt-domain ‘mvix’ ‘melatoninavix.com’ ‘www.melatoninavix.com’ ‘’ [Error 15]
E_CONNECT=15
I think the DNS records do not point to the correct server. What happens when you run the command in command line?
root@xstocler:/home/debian# v-add-letsencrypt-domain mvix melatoninavix.com www.melatoninavix.com
Error: Let’s Encrypt new auth status 429 (melatoninavix.com)
DNS is pointing to hestiacp IP correctly
log in /var/log/hestia/LE-mvix-melatoninavix.com.log
Date Time: 2021-12-01 10:13:10
WEB_SYSTEM: apache2
PROXY_SYSTEM: nginx
user: mvix
domain: melatoninavix.com
==[Step 1]==
  • status: 200
  • nonce: 0002Qw_oJT8W-aIjWGmZi3GHVaxAon9p-nGIqjTHpDhWhic
  • answer: HTTP/2 200
    server: nginx
    date: Wed, 01 Dec 2021 13:13:11 GMT
    content-type: application/json
    content-length: 658
    replay-nonce: 0002Qw_oJT8W-aIjWGmZi3GHVaxAon9p-nGIqjTHpDhWhic
    x-frame-options: DENY
    strict-transport-security: max-age=604800
==[API call]==
exit status: 0
==[Step 2]==
  • status: 429
  • nonce: 0001OGxOTN6gQtqKFKDbdb2mGkJzwQTaAzB-dX5Pl97uHl0
  • authz:
  • finalize:
  • payload: {“identifiers”:[{“type”:“dns”,“value”:“melatoninavix.com”},{“type”:“dns”,“value”:“www.melatoninavix.com”}]}
  • answer: HTTP/2 429
    server: nginx
    content-length: 295
    boulder-requester: 300610130
    link: https://acme-v02.api.letsencrypt.org/directory;rel=“index”
    replay-nonce: 0001OGxOTN6gQtqKFKDbdb2mGkJzwQTaAzB-dX5Pl97uHl0
“detail”: “Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: melatoninavix.com,www.melatoninavix.com: see Rate Limits - Let's Encrypt”,
“status”: 429
Date Time: 2021-12-01 10:45:53
WEB_SYSTEM: apache2
PROXY_SYSTEM: nginx
user: mvix
==[Step 1]==
  • status: 200
  • nonce: 0002GtLUawcgLXCDpVxcnaHUquLWqRqw5CGcpy6NXP8Z-IU
    server: nginx
    date: Wed, 01 Dec 2021 13:45:54 GMT
    content-length: 658
    replay-nonce: 0002GtLUawcgLXCDpVxcnaHUquLWqRqw5CGcpy6NXP8Z-IU
==[API call]==
exit status: 0
==[Step 2]==
  • status: 429
  • nonce: 0001zg-oa7czNuSTctLVNB5d01EwDHReY087IWA7LM0CGNQ
  • authz:
  • finalize:
    server: nginx
    content-length: 295
    replay-nonce: 0001zg-oa7czNuSTctLVNB5d01EwDHReY087IWA7LM0CGNQ
“status”: 429
https://crt.sh/?q=melatoninavix.com
Wait until Friday or Saturday and then try again
Appreciate.
I will try again on Saturday or Sunday.
