I’m trying to get a list of domains per user, outputted in a php page.
I’m playing around with the example pages found in the hestia documentation zone, i assume it’s working, because if i set returncode to yes, i get a 0 (command succesfull)
If i change returncode to no, no output comes on screen. There must be something i’m missing, maybe someone can help me to find the good way:
<?php
// Server credentials
$hst_hostname = 'yyy';
$hst_port = 'yyy';
$hst_returncode = 'no';
$hst_username = 'yyy';
$hst_password = 'yyy';
$hst_command = 'v-list-web-domains';
// Account
$username = 'aaa';
// Prepare POST query
$postvars = array(
'user' => $hst_username,
'password' => $hst_password,
'returncode' => $hst_returncode,
'cmd' => $hst_command,
'arg1' => $username,
$postdata = http_build_query($postvars);
// Send POST query via cURL
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, 'https://' . $hst_hostname . ':' . $hst_port . '/api/');
curl_setopt($curl, CURLOPT_RETURNTRANSFER,true);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($curl, CURLOPT_POST, true);
curl_setopt($curl, CURLOPT_POSTFIELDS, $postdata);
$answer = curl_exec($curl);
// Parse JSON output
$data = json_decode($answer, true);
// Print result
print_r($data);
OK, here we go…
I have changed this:
// Print result
print_r($data);
To this:
<pre>
<?php
// Print result
print_r($answer);
</pre>
The JSON decode didn’t return anything, but if i print the answer directly, i have my output.
Next step, trying to find out how i can build this up with CSS to have a nice layout.
To be continued… (I think )
eris
January 28, 2021, 9:28am
3
‘arg2’ => ‘json’,
Will return as json format
system
Closed
February 27, 2021, 9:28am
4
