Hello!
Are mysql and webmail included in the ftp constraint storage space?
So, for example, if the client is in a 1000Mb package and your mail is 200mb and the mysql database is 500Mb, can you only upload 300Mb via ftp?
Hello!
Would it be important for me to know that if I use my own ftp server for hestia, will the storage availability on ftp change?
Limits are soft limits and not enforced by default
Unless you enable the quotas but then mysql is excluded
There are not plans to drop support in the near future…
I’m sorry, I think we talked side by side. I do not understand.
So the FTP storage limit does not include: email, mysql ?
Thank you for answering!
In the user account “Package” limit we count:
Email
Database
And FTP/Web storage
If you enable system quotas
Email
And FTP/Web storage
are counted in those limits
I understand that somehow it is possible to include these with mysql ftp?
No as they are not stored in side the user dir …
With php somehow it is not possible to get all the reserved storage space via api?
On something similar to the check users and password, or as when registering, that account already exists.
Via the api you can fetch current usage for each separate and total
Can you write an example of this?
Or it’s good to describe the name of the script I can use to extract this information.
Thanks.
