Quick hack to enable ipv6 for all vhosts
Hello everyone,
I have been running HestiaCP v1.3.2 on Debian 10.6 and nginx is configured in front of apache as a reverse proxy.
I know that ipv6 is on the roadmap (Feature Request: IPv6 Support · Issue #429 · hestiacp/hestiacp · GitHub), but it’s not here yet.
Nevertheless, there is a quick and simple way to enable it for nginx sites, simply by adding an extra listen directive in the existing ipv4 vhost.
Since there is no way to configure the IPv6 address using the web-ui, we have to manually edit the config file (/usr/local/hestia/data/users/$user/web.conf) and add the IPv6 address in the IP6 field.
e.g.
root@potato:~# cat /usr/local/hestia/data/users/admin/web.conf
DOMAIN=‘potato.irc.gr’ IP=‘95.111.231.144’ IP6=‘2a02:c207:2041:3109::1’ CUSTOM_DOCROOT=‘’…
And then run this script I’ve quickly hacked, to create the listen directive needed.
root@potato:~# cat bin/v-add-web-domains-ipv6
#!/bin/bash
# configure ipv6 for all vhosts
USERS="$(v-list-users plain | awk '{print $1}')"
for u in ${USERS}; do
        DOMAINS="$(v-list-web-domains ${u} plain | awk '{print $1}')"
        for d in ${DOMAINS}; do
                source /usr/local/hestia/data/users/${u}/web.conf
                if [ -n "$IP6" ]; then
                        echo "listen [${IP6}]:80;" > /home/${u}/conf/web/${d}/nginx.conf_ip6
                        [ "$SSL" == "yes" ] && echo "listen [${IP6}]:443 ssl http2;" > /home/${u}/conf/web/${d}/nginx.ssl.conf_ip6
                else
                        rm -f /home/${u}/conf/web/${d}/nginx.conf_ip6
                        [ "$SSL" == "yes" ] && rm -f /home/${u}/conf/web/${d}/nginx.ssl.conf_ip6
                fi
        done
done
nginx -t && systemctl reload nginx
Here is the script output…
root@potato:~# cat /home/admin/conf/web/potato.irc.gr/nginx.conf_ip6
listen [2a02:c207:2041:3109::1]:80;
root@potato:~# cat /home/admin/conf/web/potato.irc.gr/nginx.ssl.conf_ip6
listen [2a02:c207:2041:3109::1]:443 ssl http2;
You may now add an AAAA record in the DNS zone file and it shall work :wink:
Please note that this is only a quick hack.
It only works for websites behind the nginx service.
It does not substitute proper ipv6 support in HestiaCP’s core.
Thanks,
Sot.
thanks for the guide mate, actually it works like a charm but unfortunately if there is any other user than admin, this shows SSL error and fetch SSL from default admin web. please help regarding this.
Can you share more details please?
I can’t understand the problem from your description.
hey mate I’ll give you access to my testing server tomorrow then you’ll check it yourself.
Is this still safe to do on the current hestiacp release? Place I do work for requires me to run a domain with ipv6, and I would like to enable it for the entire server…
I still use this method – currently running HestiaCP v1.6.14 (latest) …
Except this messes up LetsEncrypt verification!
See SSL Certificates and Let's Encrypt — Hestia Control Panel documentation
Do you have an undo script for those changes as well?
Sure, just delete the IP6 address from the conf file and re-run the script.
It will remove the extra files it created on the previous run.
Just removing the nginx ip6 conf file from the admin domain dir was enough.
Important to remember though; Re-running the script does not recreate the LetsEncrypt certs, and you’ll find that some have been linked to an IPv6 address! This causes certificate updates to fail, and ultimately, without you knowing, creates a mess of your system.
