Hello everyone, I hope you can help me.
I have configuration problems with my server, basically, randomly, some APIs that usually take 200-600ms to execute, take 10-20 seconds.
Thanks to logs and several tests, I ruled out that the problem was the connection to the Database, in fact even APIs that do not query the DB but return a static string give me the same problem if called several times.
Here are some cases and tests carried out:
My back-end is written with Laravel, my hosting is Contabo and has already migrated the server and improved performance, but the problem persists.
These are some configurations I have, if you need more details let me know::
APACHE2
Timeout 30
KeepAlive Off
MaxKeepAliveRequests 100
KeepAliveTimeout 10
NGINX
sendfile on;
tcp_nopush on;
tcp_nodelay on;
client_header_timeout 180s;
client_body_timeout 180s;
client_header_buffer_size 2k;
client_body_buffer_size 256k;
client_max_body_size 256m;
large_client_header_buffers 4 8k;
send_timeout 60s;
keepalive_timeout 30s;
keepalive_requests 100000;
reset_timedout_connection on;
server_tokens off;
server_name_in_redirect off;
server_names_hash_max_size 512;
server_names_hash_bucket_size 512;
charset utf-8;
# FastCGI settings
fastcgi_buffers 8 256k;
fastcgi_buffer_size 256k;
fastcgi_busy_buffers_size 256k;
fastcgi_temp_file_write_size 256k;
fastcgi_connect_timeout 30s;
fastcgi_read_timeout 450s;
fastcgi_send_timeout 300s;
fastcgi_cache_lock on;
fastcgi_cache_lock_timeout 5s;
fastcgi_cache_background_update on;
fastcgi_cache_revalidate on;
# Proxy settings
proxy_redirect off;
proxy_set_header Host $host;
proxy_pass_header Set-Cookie;
proxy_buffers 32 4k;
proxy_connect_timeout 30s;
proxy_read_timeout 300s;
proxy_send_timeout 180s;
I hope you can help me, because I’m going crazy.
