Raspbian 11 bullseye .deb package not found
hi,
when try to install hestiacp on Raspbian 11 (64bit) with bellow .deb packages link but get 404 error.
https://apt.hestiacp.com/beta/debian-11/hestia_1.5.0~beta_arm64.deb
https://apt.hestiacp.com/beta/debian-11/hestia-nginx_1.21.3_arm64.deb
https://apt.hestiacp.com/beta/debian-11/hestia-php_7.4.25_arm64.deb
can you provide latest link please.
thank you,
  • NOTE: Hestia packages for arm64 has been added to atp.hestiacp.com please use the normal install instructions instead! For current ARM installs to enable auto update remove the # in /etc/apt/sources.list.d/hestia.list # deb https://apt.hestiacp.com/ focal main becomes deb https://apt.hestiacp.com/ focal main and then run apt update && apt upgrade -y
Source: Release notes for HestiaCP v1.5.0 — Hestia Control Panel documentation
Just use the installer…
Install successfully without any issue… thank you team :heart:
We have automated the building process for deb packages for ARM64 processors allowing us to distribute them via our atp server…
successfully install. thank you brother…
