Hi guys !
First of all, the following problem only occurs with the “admin” user.
I have tried with common users (who do not have admin role) and everything works fine.
In the user “admin” I have this cronjob: rclone sync “/backup” “hcpbackup:b2bucket/folder”
The files upload is done correctly in Backblaze, but what is not done well is the deletion of the old files in Backblaze (they should be deleted because I’m doing a “sync”)
In the Rclone log I found these errors:
2023/04/17 23:12:15 ERROR : B2 bucket b2bucket path backup: not deleting files as there were IO errors
2023/04/17 23:12:15 ERROR : B2 bucket b2bucket path backup: not deleting directories as there were IO errors
Searching the documentation and the Rclone Forum I found that the “–ignore-errors” flag should fix the problem because this flag does: “Delete even if there are I/O errors”
Using the “–ignore-errors” flag, the above errors disappeared from the Rclone log, but the problem persists, that is, the files or directories on the destination (Backblaze) are not deleted.
I have searched in other forums, but apart from that flag, I have not found any solution.
Has something like this happened to anyone?
Has anybodey a cronjob using Rclone with user “admin”?
Thanks and good week!
