Good evening, I have a problem when I configure the backup on rclone I get this error. What is it due to?
manually works fine
rclone move /backup tecinf:backuplinux
thanks
manually works fine
thanks
What happens if you run:
rclone config
Use root user and it should work
it’s in the control panel that I can’t set it
sudo -s
And it should you login as root if not you should contact your provider.
We run clone under the root user so configs under the root user are currently used.
Should should be able to login to you server as root. And it should work fine
