Hi, I setup rclone on my server to backup on mega repository and the test.txt backup worked. When I try the command v-add-backup-host begins the problem.
As you can see in the screenshot…
How can I solve this? Thank you
Run with sudo
or as root
You need to run: rclone config as root user not as “ubuntu” user
it will create the config under the root user…
Thank you, I’ve done and it works. Great! Thank you man!
