Hello, I am trying to reach Hestia on my backend server (not only hestia) behind cloudflare and nginx proxies.
I would continue to use Hestia through the IP directly but I can’t open phpmyadmin and the fix for this from the documentation didnt work for me.
cloudflare is set to flexible SSL pointing to a proxy server which is pointing to another proxy server which is pointing to the hestia server.
I didnt manage to setup full ssl because I would need extra domains/subdomains for every proxy server.
proxy 1 configuration:
server {
listen *:80;
server_name example . com hcp.example . com www.example . com;
client_max_body_size 100M;
proxy_read_timeout 600s;
proxy_buffer_size 128k;
proxy_buffers 4 256k;
proxy_busy_buffers_size 256k;
location / {
proxy_set_header CF-Connecting-IP $http_cf_connecting_ip;
proxy_set_header Host $host;
proxy_pass http://proxy-2-IP;
proxy 2 configuration:
server {
listen *:80;
server_name example . com www.example . com;
location / {
proxy_pass http://backend-IP;
server {
listen *:80;
server_name hcp.example . com;
location / {
proxy_pass http://backend-IP:8083;
