I followed this tutorial to install NodeJS on HestiaCP. It generated (1) nodeapp, and (2) public_html folder.
I have a React + Laravel web app. React acts as the front-end, and Laravel acts as the back-end. I run this on my Windows machine perfectly with Cloudflare Tunnel. But now, I want it to be put on my HestiaCP installed on an Oracle Cloud VPS running Ubuntu 22.04 ARM64.
React Folder
$ npm start
Laravel Folder
$ php artisan serve --host localhost --port 3001
I put the React folder in the nodeapp folder, and the Laravel folder on public_html folder.
Unfortunately, Cloudflare responded to 502 Bad Gateway. Is there any workaround to make it run perfectly?
Thank you.
