I have Ubuntu 22.04 and plan the upgrade to 24.04. However, upon looking at the documentation it mentions “Verify that MariaDB is running at least version 11.4. If not, first upgrade to this version in your current operating system!”
What is the recommended way to upgrade MariaDB. Can I simply change the mariadb.list to 11.4 and do apt update && apt upgrade and Do I need to add a new keyring? There is also a script upgrade_mariadb.sh under the manual folder. Can I just change the version on that and run it?
While I am at it. My other server uses Mysql, is there any updates I need to do there?
Thanks for the help.
