Redirect to www
Greetings,
I need to redirect to www, every time the site is visited without the www.
I found this ngix solution online:
server {
listen 80;
server_name www.domain.example;
# $scheme will get the http protocol
# and 301 is best practice for tablet, phone, desktop and seo
return 301 $scheme://domain.example$request_uri;
server {
listen 80;
server_name domain.example;
# here goes the rest of your config file
# example
location / {
        rewrite ^/cp/login?$ /cp/login.php last;
        # etc etc...
Hi ave:
server {
listen 79.137.87.44:80;
server_name weddingsmart.it www.weddingsmart.it;
error_log /var/log/apache2/domains/weddingsmart.it.error.log error;
So on the same line I have both weddingsmart and magazine.weddingsmart.
This information is in the ngix configuration file, both the normal one and the .ssl one
How can I make the change and in which file do you recommend doing it?
Thank you
And it should be enough…
Also don’t make changes directly to the config files…
Perfect thanks!
