I have Redis installed and its showing the following error on redis-server.log
933:M 24 Sep 2020 23:49:06.817 # WARNING you have Transparent Huge Pages (THP) support enabled in your kernel. This will create latency and memory usage issues with Redis. To fix this issue run the command ‘echo never > /sys/kernel/mm/transparent_hugepage/enabled’ as root, and add it to your /etc/rc.local in order to retain the setting after a reboot. Redis must be restarted after THP is disabled.
I tried what’s the warning suggests, I created the file in the directory /etc/rc.local because I don’t have it. Then I tried to add the following line to it. but that didn’t fix the problem.
Can you help me fix this error.
