Release data for version Ver 1.1
@mmgnservices for new installs, please have a look here: https://github.com/hestiacp/hestiacp/issues/568#issuecomment-521086717
Hi guys,
any chanche you release v. 1.1.0 this weekend?
no, we currently prepare the docs due to importantly needed informations for migration steps. The release should be around next week.
I just ran ā€œdpkg -i hestia_1.1.0_amd64.debā€ on a fresh installation of Debian 10.3.0 and got the following:
Unpacking hestia (1.1.0) ...
dpkg: dependency problems prevent configuration of hestia:
 hestia depends on acl; however:
  Package acl is not installed.
 hestia depends on sysstat; however:
  Package sysstat is not installed.
dpkg: error processing package hestia (--install):
 dependency problems - leaving unconfigured
 hestia
And if I try to install those two dependencies I get the following:
The following packages have unmet dependencies:
 sysstat : Depends: libsensors5 (>= 1:3.5.0) but it is not going to be installed
Any ideas before I try to troubleshoot?
did you run
apt install -f
afterwards or did you eventually specify the missing packages individually or omitting the force command?
DOH!!! Hahaha! No, I hadn’t even look at the next line since that dpkg line had given the errors—it didn’t occur to me that that was normal :slight_smile: . That did the trick.
Thanks! :crazy_face:
To all who helped out testing the beta version of Hestia: Thank you for your awesome work, 1.1.0 has been released!
Due to changes of the version, please install the new gpu key (https://forum.hestiacp.com/t/hestia-1-1-0-released) and use apt to reinstall the package:
apt-get update && apt-get install --reinstall hestia
