Release of 1.4.1
We are happy to announce that Hestia 1.4.1 has been released in our repository a few minutes ago!
Please run apt update && apt upgrade in the command line.
Please check hestiacp/CHANGELOG.md at release · hestiacp/hestiacp · GitHub for the change log.
  • Warning: As Nginx has decided to release Nginx 1.2.1 (Mainline) yesterday you get a prompt where you are asked to replace nginx.conf. Please press N or enter.
For 1.3 users:
  • NOTE: Ubuntu 16.04 (Xenial) is no longer supported as it has reached EOL (end-of-life) status.
  • NOTE: Apache in “standalone” mode is no longer actively supported and has been removed from installer options. Nginx (Proxy) + Apache2 will remain supported.
  • NOTE: Custom “quick installer apps” will not work anymore due to changes in how we handle quick installer apps. Minimal changes to the Quick installer apps are required! Please check GitHub - hestiacp/hestia-quick-install for how to migrate!
  • NOTE: Manual upgrade scripts are available to update Roundcube and PHPmyadmin to the last version they can be found in /usr/local/hestia/install/upgrade/manual/
https://docs.hestiacp.com will follow shortly with an update.
NOTE: 1.4.0 are strongly advised to upgrade to 1.4.1 as it contains a bug in login system!
Example message:
Configuration file '/etc/nginx/conf.d/default.conf'
 ==> Deleted (by you or by a script) since installation.
 ==> Package distributor has shipped an updated version.
   What would you like to do about it ?  Your options are:
    Y or I  : install the package maintainer's version
    N or O  : keep your currently-installed version
      D     : show the differences between the versions
      Z     : start a shell to examine the situation
 The default action is to keep your current version.
*** default.conf (Y/I/N/O/D/Z) [default=N] ? N
Installing new version of config file /etc/nginx/mime.types ...
Configuration file '/etc/nginx/nginx.conf'
 ==> Modified (by you or by a script) since installation.
*** nginx.conf (Y/I/N/O/D/Z) [default=N] ? N
