How do I connect remotely (for example, using HeidiSQL) to the MariaDB database with db_user_name and password (not root)?
I set
bind-address = *
in /etc/mysql/my. cnf - it doesn’t help. Disabled iptables and fail2ban-also did not help.
What else can I see?
Hello Maxim, try this instead:
[mysqld]
bind-address = 0.0.0.0
Afterwards you can confirm with
sudo netstat -ntlp | grep -E "(mysql|maria)"
[mysqld]
it doesn’t help
sudo netstat -ntlp | grep -E “(mysql|maria)”
netstat: command not found
apt install netstat cowsay && echo “now I have netstat installed” | cowsay
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 96676/mariadbd
But not connecting.
telnet 123.123.123.123 3306 - say “Could not open a connection to this node, on port 3306”
What else to pay attention to?
"Could not open a connection to this node, on port 3306” it’s a great tip for your question.
how will this help me? what should I do?
Did you restarted the mysql service after changing the conf?
of course
I think the output of the netstat command is showing that mariadb service is listening on localhost only (127.0.0.1).
Have a look at the bold in this StackOverflow answer. Maybe it’s related.
I realized what the problem was.
I set bind =0.0.0.0 in the Hestia panel itself in the mariadb config settings.
And it was necessary to change this value in the file /etc/mysql/mariadb.conf.d/50-server.cnf.
And now question: why are the mariadb config settings ignored in the hestia panel?
In the /etc/mysql/mariadb.conf.d/50-server.cnf file i set
And the remote connection to the database works.
But why can’t I connect remotely if I set my IP?
bind-address = 123.123.123.123
Because its probaly a different config file. I usualy always suggest to adjust them on shell instead web, it just makes more sense. About the request itself, this has added a while ago to our docs: Database — Hestia Control Panel documentation
