I’ve Remove STRICT_TRANS_TABLES from phpmyadmin but after some days its auto add on phpmyadmin again… how to permanently remove this?
How did you removed it?
From phpmyadmin using root+password
Probaly you want to disable it over the service itself? macos - How do I disable STRICT_TRANS_TABLES for a Homebrew-installed MySQL server? - Stack Overflow
Thank You Sooo Much
