Is there a way to remove Rainloop email client, was installed with v-add-sys-rainloop?
I read some posts that say Rainloop has security risks.
Regards.
Regards.
Delete:
/var/lib/rainloop
/etc/rainloop
and /var/log/rainloop
Then remove in /usr/local/hestia/conf/hestia.conf WEBMAIL_SYSTEM rainloop and the, before or after it
This may make sense to replace rainloop with snappymail entirely in HestiaCP
Snappymail is a fork of the latest rainloop 1.16.0
See the comparison between Rainloop and Snappymail, its pretty substancial
For Reference I Opened Feature / Bug Issue on HestiaCP Github
Already checked if it was an suitable replacement…
Thanks!
This will be a good alternative.
Budy,
Looks like the forum link on your GitHub post is wrong.
Regards.
Changed it
@eris as always very fast… (y)
Fantastic! @eris will be looking forward to the switch over from rainloop to snappymail, we just switched back to Roundcube Webmail for now. Thanks again!!
