Hi all,
It’s time for me to renew my SSL (with namecheap) what’s the best way to generate a new CSR? Do I have generate a self signed again?
Thanks for the reply!
Hi all,
It should be possible to keep the current CSR / Key but it is always suggested to create a new CSR
Thanks, is it possible to get the old CSR from Hestia so I don’t have to digging up an email for it?
In the /usr/local/hestia/data/users/{user}/ssl/ dir should the csr exists if not just generate a new one it is saver any way
actually found that had everything but the CSR
unless its possible to convert a key into a csr?
or how to I get a new csr from Hestia?
Edit web → Generate self signed cert → Fill in the data and save…
