Just installed on a test vps and works perfect. great work!
Is it possible to replace exim with postfix and integrate the dovecot sieve as in this post? vesta forum link
Using release version on Ubuntu 18.0.4
Just need to double check any path changes.
Thank you in advance.
Hi salnz
Baiscly, you could do it, yes. But to be honest, we do not suggest this modification - better use the integrated way over exim.
Ok thanks for the reply
I have managed to integrate these still using exim and default installed versions Rspamd (and gui link in Hestia menu), Dovecot using imap sieve and email pipe to Rspamd Other than those have added Brotli support into Nginx Webp support in php gd
