v-backup-users will backup all users.
Nothing yet for system config
now i use trash-cli !!!
and timeshift
https://doc.ubuntu-fr.org/timeshift
Hi @eris
I run your install script manually. There is a variable called HESTIA_COMMON_DIR that not exists or set. So whats the right HESTIA_COMMON_DIR path?
root@SRV-NETC-04:~/downloads$ echo $HESTIA_COMMON_DIR
This variable is set in line 57 at file hestiacp/install_sieve.sh at main · hestiacp/hestiacp · GitHub
Yes …
HESTIA_COMMON_DIR=“/usr/local/hestia/install/deb/” will work fine
In a future release we will change that to
/usr/local/hestia/install/common/
(After RHEL support has been added)
The right path is /usr/local/hestia/install/deb/ (at my server).
After I added this line HESTIA_COMMON_DIR="/usr/local/hestia/install/deb/" into my install script, the sieve filter was installed correctly. Now I cann add some filters.
Linux Version
Distributor ID: Debian
Description: Debian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
