Restic disable / Please help
Good day
I installed the beta version of the panel. I really liked that there were restrictions on the use of memory and processor for users.
The question is - how can I disable the new type of Restic backup and return to the old one? If I disable Restic, then no backup is made at all.
Or can someone give instructions on how to configure Restic for backup on ftp
Thank you very much!
There is a backup in v-backup-users
Just replace it with:
You might also can just disable backup cron by deleting it from cli
