When restoring a vesta backup to hestia it does not recreate the package. Is this a bug?
Under users it shows the package name but when going to packages it does not show the packages from vesta server.
Hestia doesn’t create the packages you need to make them first
If i create the packages first i have to create the packages with the same name ?
Will hestia take the settings of the previous server package or the current server package ?
Yes you can also copy the same files from /usr/local/vesta/data/packages/ and copy them over to /usr/local/hestia/data/packages/
Cool, thanks for your help. Will use that in my next migration, ive already moved 70% of my servers from vesta ![]()
