For additional security, we’re testing adding a specific static IP for admin login.
I tried changing the Hestia login from 0.0.0.0/0 to 123.123.123.123 but I was still able to get to the admin page and login with a different IP. I then reverted the IP back to the original setting and added a second firewall rule with the additional IP - same result. Both times I did restart fail2ban and iptables.
Wondering what I’m doing wrong and is there a way to restrict the :8083/login page and login permissions to a specific IP address?
You can restrict access to Hestia from a specific IP (via firewall or Nginx configuration), but you can’t restrict access to the admin user only without modifying Hestia’s PHP code.
I suppose you are changing the allowed IPs to access Hestia’s API, not the login page.
So if I understand this, to allow only 1 IP address to access the admin panel, replace the 0.0.0.0/0 rule with the IP I want to allow access to the admin panel? If so, I tried that and was still able to access the panel with a different IP.
RULE ACTION PROTO PORT IP SPND DATE
1 ACCEPT ICMP 0 0.0.0.0/0 no 2014-09-16
2 ACCEPT TCP 8083 0.0.0.0/0 no 2014-05-25
9 ACCEPT TCP 80,443 0.0.0.0/0 no 2014-09-24
10 ACCEPT TCP 22 0.0.0.0/0 no 2014-09-16
11 DROP TCP 0 ipset:Blacklist2 no 2025-07-20
13 DROP TCP 0 ipset:ipdb7day no 2025-11-19
-P INPUT DROP
-P FORWARD ACCEPT
-P OUTPUT ACCEPT
-N fail2ban-HESTIA
-N fail2ban-RECIDIVE
-N fail2ban-SSH
-N fail2ban-WEB
-N hestia
-A INPUT -p tcp -m tcp --dport 22 -j fail2ban-SSH
-A INPUT -p tcp -m tcp --dport 8083 -j fail2ban-HESTIA
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -s 123.123.123.123/32 -j ACCEPT
-A INPUT -s 127.0.0.1/32 -j ACCEPT
-A INPUT -p tcp -m set --match-set ipdb7day src -j DROP
-A INPUT -p tcp -m set --match-set Blacklist2 src -j DROP
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 8083 -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A fail2ban-HESTIA -j RETURN
-A fail2ban-RECIDIVE -s 142.93.230.77/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 159.223.0.49/32 -j REJECT --reject-with icmp-port-unreachable
-A fail2ban-RECIDIVE -s 174.138.14.223/32 -j REJECT --reject-with icmp-port-unreachable
(truncated)
-A fail2ban-SSH -j RETURN
-A fail2ban-WEB -j RETURN
I had switched the IP back to the original value to ensure I could still access the panel.
