I am trying to create a nginx template to reverse proxy a subdomain to my own selfhost server docker container (N8N). However, I find that it’s veryslow and becoming timeout for even the first page.
My template set like this.
server {
listen %ip%:%proxy_ssl_port% ssl;
error_log /var/log/%web_system%/domains/%domain%.error.log error;
ssl_certificate %ssl_pem%;
ssl_stapling on;
ssl_stapling_verify on;
# TLS 1.3 0-RTT anti-replay
# Block access to hidden files
deny all;
return 404;
location / {
proxy_ssl_server_name on;
proxy_ssl_name $host;
proxy_pass http://myownserverDOMAINNAME:5678;
proxy_http_version 1.1;
# Performance improvements
proxy_buffering off;
proxy_cache off;
chunked_transfer_encoding off;
# Essential Headers
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $host;
# WebSocket support
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
# Extended timeouts for n8n
proxy_connect_timeout 3600s;
proxy_send_timeout 3600s;
proxy_read_timeout 3600s;
location /error/ {
add_header X-Frame-Options "SAMEORIGIN";
add_header X-XSS-Protection "1; mode=block";
add_header Content-Security-Policy "upgrade-insecure-requests;";
add_header X-Content-Type-Options "nosniff";
add_header Referrer-Policy "strict-origin-when-cross-origin";
